over heating problem??
Old Apr 22, 2007 | 08:32 PM
seppy's Avatar
Default over heating problem??
hello all, and thanks in advance for any help in diagnosing my problem. 93 honda civic 1.5 litre 5 spd. engine seems to only over heat when going up long hill. i put on new water pump cause it was leaking. new timing belt thermostat and filled up rad. when going up hill the temp gauge rises fast and when i turn the heater on full hot the gauge drops down to normal. im thinking the temp sensor??? any help would be appreciated. thanks
Old Apr 22, 2007 | 09:16 PM
hatch46580's Avatar
Default RE: over heating problem??
your fan working??
Old Apr 22, 2007 | 09:57 PM
seppy's Avatar
i will check for power to fan. if the temp sensor is bad will this cause the fan to not operate?? some more info to add is when i got home after a long drive the rad hose going to the thermastat was cold, meaning the thermastat is not opening.
Old Apr 22, 2007 | 10:03 PM
hatch46580's Avatar
or you have a big air bubble in the system, did you bleed the coolent when you changed all that stuff, a little nipple on the water neck, coming off the head??
Old Apr 22, 2007 | 10:24 PM
seppy's Avatar
ok thanks ill try that too
Old Apr 23, 2007 | 06:37 AM
In case you're not familiar, CLICK HERE for a how to on bleeding the coolant system
EXcommuter
May 31, 2014 08:08 AM
Big Mick
Jun 25, 2010 09:02 PM
prodigyskate5
May 7, 2009 07:11 AM
joeycstngy
Feb 29, 2008 11:06 AM
jad1217
Dec 7, 2005 08:56 PM
