Overheating, cooling fans not coming on
Old 02-01-2015, 06:00 AM
jonk198's Avatar
Default 99 civ, Overheating, cooling fans not coming on
My cooling fans will not come on, ive checked fuses and switched relays they turned out good. But when i Short out my connector running to my thermostat (fan switch) itself the fan kicks on. i replaced the fan switch with high hopes of it running but no luck there. im at a loss, any ideas??
Old 02-01-2015, 06:54 AM
The fan will not come on if there is no flow through the radiator-- due to lack of coolant, clogged radiator, thermostat stuck closed, etc. Test drive with the connector jumpered so the fan runs all the time and confirm no overheating. If it still overheats, obviously the problem is something other than the fan control.
Old 02-01-2015, 07:13 AM
jonk198's Avatar
i appreciate it, i'll try it and see what happens
ianer167
03-16-2012 04:42 PM
Leopold
08-15-2011 06:14 PM
catherinebrook11
05-18-2011 08:31 PM
Blammo300
04-15-2007 05:55 PM
Dwight
05-07-2004 11:01 PM
Quick Reply: Overheating, cooling fans not coming on
