Possible clogged heater core
Old 02-04-2017, 01:37 PM
04civiclover's Avatar
Default Possible clogged heater core
So after I finally got my coolant system burped, was which not easy due to the single digit weather we have been having in michigan I notice while driving my heat was fluctuation. I run a ob2 scan guage 2 on the dash so i car see real time engine data. During the head gasket issue i could see temp fluctuation pretty accurately down to 5 degrees. So recently the temps took a cold dive and i have the heater on full blast. First few days heat was deathly hot, then i noticed it wasn't as hot. Then next day deathly hot. Lat night it was really hot, then luke warm. I thought ****, here we go I lost coolant. But guage showed little change and i popped the hood system was full. Now when I did the timing belt 60k ago i also did the water pump. When I refilled I just used regular universal coolant. During the head gasket, working the cold I didn't drain the radiator. I tried to stay off the garage floor as much as possible. But I did replace the thermostat, was not a stant think it was made in isreal. I have read people saving they had a gelling issue with mixing Honda coolant, im surprised since it was already mixed. Oh yeah i also checked the heat/cold valve under the hood. Moved both ways.
Old 02-05-2017, 07:35 AM
So i braved the cold weather this morning and removed my airbox, and drove over to the local car wash. Once there I removed the hoses going from the engine to the heater core.(supply and return) Then i stuck the power washer on low and let it run until the fluid turned from white to clear water. Now I'm in the process of bleeding the system again.
mr honda
19
01-11-2008 11:04 PM
HB Pickup Truck
10-07-2007 09:12 AM
97silver
10-03-2006 08:23 PM
kinosh
03-28-2005 08:57 PM
mcbob
11-29-2004 11:15 AM
Quick Reply: Possible clogged heater core
