short shifter
Not difficult. In my opinon, the hardest part is actually getting to the shifter and linkage above the exhaust pipe. It is much easier to just remove the B pipe (but I have removed mine a few times so it is easier - The first time removing exhaust is the worst!)
Also keep note that if it is the transmission grinding, a new shifter won't do anything to help, it will actually make it worse, as a short shifter will "slam" into gears.
That's the short form, anyways.
DC integra stock shifter is a dual bend and can be had for cheap. It has a slightly shorter throw than stock. A slight mod must be done to make it fit, but, it's a really nice upgrade. I've got one in my EF.
I got mine from an auto wrecker. It was like $10 lol. Try ebay, there is probably one on there.
Part number is 54101-ST7-000
Alright so I'm going to assume you haven't had explained what the "throw" of a shifter actually is.
There's 2 distances to worry about. 1 is the shifter length, from the pivot point "ball" to the shift ****. It doesn't affect throw, just the height of the shifter.
The throw is the distance from the pivot point "ball" and the lower bushing/where it connects to the shift linkage.
greater distance between pivot ball and bushing = less travel for the **** from gear to gear. since there is a shorter throw, people tend to shift faster, which can wear out the gear synchros in the tranny much faster.
having a shifter sitting on your floor won't help you. I laugh at the guys around here that cut the stock shifter and glue on a ****... it's just dumb, doesn't help anything.
this link explains it better DIY Integra GSR Shifter install into Civic - D-series.org i hope that link is allowed lol
I had to stretch my shift boot a bit. It's funny, I have an integra center console w/ shift boot, as well as my integra shifter, and it stretched the boot! lol...
Good ole Legos.... err... Hondas. :P
Mr^Man
Transmission and Differential
10-19-2008 04:21 PM
addiction2bass
12-25-2007 10:46 AM
heathershonda
12
05-10-2007 07:18 AM
ELECTRON BLUE 2000
04-18-2007 11:00 AM
05CivicLX
06-04-2005 12:46 PM
