Trouble Starting 1991 Civic DX
Howdy. I have a beloved old light blue Civic that is just about 320,000 miles old. It's been a great car to me. Recently, I've had a few problems from leaving the car several days without using it. This problem in particular has become extremely drawn-out and I'm at the end of my rope.
I describe this as concisely as possible. A month ago I replaced everything from the distributor coil to the spark plugs. Then, when I knocked out the passenger front window and had to replace it, the car sat for 5 days until got it fixed. Left the key in the on position the whole time like a dummy. That was fine because the battery was bad anyway. So I replaced it and the 60 amp fuse in the hood fusebox, which was blown. Still won't start. The starter is in good shape and it's turning over. I have gotten the engine to putter with the key in the start position a few times, but it will not run on its own.
This is everything I've checked:
-All fuses. All good.
-Fuel pump is priming in the back.
-No cracked hoses in the front, no fuel leakage on the ground.
-I am getting sparks to all four spark plugs.
-Just replaced the small fuel regulator on the driver side of the throttle body. It wasn't working properly.
-I haven't had any compression issues since the engine was rebuilt around 160k miles.
The last thing I know of would be the injector main relay. Any other suggestions? This thing needs to get back on the road soon. I would greatly appreciate any advice. Thanks all,
Bennette
Bennette
CatsnotCars
01-28-2015 12:24 PM
Rescue56
02-25-2008 05:06 PM
