Starting Trouble
Old 06-27-2008, 05:53 PM
maffei34's Avatar
Default Starting Trouble
Hello occasionally my 98 Honda Accord wont start. I hear the clicking noise but it wont start so im pretty sure its not the starter. 15 minutes later it will start. I also recently had my battery changed so its not that. I had my alternator tested and they said its fine. Does anyone know what else it could be ?? Im supposed to be leaving tomorrow for a 20 hour drive to Arkansas.Would like to fix this before i leave.
Thanks,
Nick
Old 06-27-2008, 06:04 PM
Default RE: Starting Trouble
If you are saying that occasionally the engine will not crank when you turn the ignition key to start, then the starter may be going bad or the electrical connections to the starter may be loose or making poor contact due to corrosion.
Old 06-27-2008, 06:06 PM
Live_4it's Avatar
is it a fast clicking sound? I think it's the starter on it's way out. Or could be a bad ignition switch...
how long has it been since you did a tune up? distributor cap and rotor, plug wires, thats what I would try first. Or just try cleaning the rotor and cap where the points touch first. If there is white corosive build up on them.
Old 06-28-2008, 10:47 AM
mundy5's Avatar
our 6th gen had a recall on the ignition switch. make sure it was replaced.
Old 06-28-2008, 11:11 AM
ORIGINAL: mundy5
it's an accord, not a civic
anyway, i had this problem with my old civic and it turned out to be my battery cables not being tight enough on the battery posts. I couldn't tighten them anymore so I bought these lead things from the auto parts store that go over the posts in order to make the posts bigger.
CatsnotCars
01-28-2015 12:24 PM
blkstallion
06-11-2007 07:55 AM
Rainingbullets
12
07-21-2006 12:44 PM
Driveracrx
01-02-2006 03:44 AM
blaure
05-09-2005 12:51 AM
Quick Reply: Starting Trouble
