new to board, need some help on engine problems
hey wassup guys, im located in brooklyn ny and i got a 1993 honda civic LX, the car is in great shape but has some minor problems. My car shakes whenever i turn on the ac for some reason, the shaking get to point where it scares me sometimes. Im not sure where the problem occured but any help is appreciated. Another problem i have is the steering wheel seems very stiff, i tried putting in power steering fluid but it didnt work. One last problem i have is the left front window doesnt seem to open, the rest of the windows does.
ANy help is appreciated, im a noob on cars and i would bring it to a garage (and get raped charges) if that is my last option
Thanks.
Thanks.
RE: new to board, need some help on engine problems
ORIGINAL: kewlphil
ORIGINAL: ngoti8tor
Can you elaborate on that a little? Like, was it already full, or after you added some fluid, the steering was still stiff?
ORIGINAL: kewlphil
the fluid was near full but i added a bit into it anyway but it didnt help
If your car shakes under load violently it could be that you need some more motor mounts, or it could be a number of things like bad plugs, or belts too tight etc. How does it run with the AC off? Does it shake less or not at all. Left front window may need another regulator, or it could be a bad switch. You might just have to pay $30 somewhere and have them check out all your issues. It's difficult to tell what's wrong without seeing or hearing the car.
yeah it only shakes when i open the ac, i guess ill just check it out at the mechanic
ORIGINAL: jake11375
