driver door window regulator
Old Mar 30, 2009 | 02:33 PM
codered3x's Avatar
Default driver door window regulator
window regulators broken... i don't really need specifics, i just wanted to get some idea of how hard this repair is... also is 75 dollars a reasonable price for the setup ( manual crank regulator)
Old Mar 30, 2009 | 02:36 PM
I had to pull the broken one out of my sister's 99 DX. It wasn't too bad. There were several screws to take out, then I had to take the window off the regulator, but it wasn't bad at all. If you're comfortable with tools, you'd do fine.
Old Mar 31, 2009 | 01:33 PM
scoob8000's Avatar
Is it really broken? I've got my door apart right now trying to fix mine (94 4 door).
The window gets cocked unless you kept the glass slid rearward while cranking when putting it up. I can't see anything broken.
With the window half way down I can slide the glass forward and backwards in the track a good 3/8" or so. I think that may be the problem, but I don't see any track adjustments..
Old Mar 31, 2009 | 02:59 PM
On yours, you might just need to tighten up the bolts on the glass and spray some silicone lubricant in the tracks so it doesn't get stuck, causing it to lean forward or backward.
Old Mar 31, 2009 | 04:34 PM
codered3x's Avatar
well it wasnt really broken until my drunk *** tried to crank it up when it had come of the track.... btw shouldn't honda have done some recalls or something about those horrible tracks...
Old Mar 31, 2009 | 05:24 PM
jprommel's Avatar
Angry Admin
cowsgonemadd3
Nov 19, 2009 02:32 PM
packman5280
Nov 17, 2007 06:07 AM
rss0213
Oct 5, 2007 07:16 AM
97civic123
Sep 25, 2007 06:30 PM
civic95
May 20, 2005 08:48 PM
