f22 tb on d16y8
Old Feb 27, 2009 | 09:32 AM
0ekex's Avatar
yea if you would that would be great, so you think the tps being missadjusted is what causing my high idle issue. the only way to adjust it is to lossen the screws amd rotate the sensor right.
Old Feb 27, 2009 | 12:43 PM
intenseneal's Avatar
Yeah thats right but you need a multi meter to get it in the right spot I believe. I will look through the manaual and see today.
Ok here it is the tps needs to about about .49 volts fully closed and 4.5 volts fully open. This is the test of a p0122 code for low tps sensor voltage. Good luck this can be a pain to fix or it can be simple, it just depends.
Old Mar 1, 2009 | 07:36 AM
  #23
0ekex's Avatar
thanks for all the help guys it actuly ended up being the idle air control valve.
mike1990civic
ED-EF Swaps
Jun 25, 2006 11:37 AM
mike1990civic
ED-EF Swaps
Sep 1, 2005 01:53 PM
GotRice?99ex
Aug 15, 2005 11:49 PM
mike1990civic
Jul 3, 2005 04:03 PM
