Aftermarket transmission Filter
Old Nov 7, 2009 | 02:33 PM
doy's Avatar
doy
Default Aftermarket transmission Filter
Is there an aftermarket filter available for Civic automatic transmissions?
Old Nov 9, 2009 | 04:51 AM
xero_xero's Avatar
As of at this moment, no there are no performance transmission filters.
i dont see this being neccessary. oem filters are to stop begnin material from intering the valve body and the pump and this only happens when somethig breaks.
**You should never have to add transmission fluid, these dont burn fluid, if it is leaking and you do have to add it, there is a problem.
**Flushes should only be dont on HIGH miledge transmissions due to the parts wearing much more than originally (ie spaces are not to original spec but have been broken in quite a bit more there fore larger spaces for fluid to get compressed resulting in a more used and darker fluid)
**If you choose to do services, use the correct automatic trans fluid specified by manufacturer. NO!!! - AUTOMATIC TRANS FLUIDS ARE NOT ALL THE SAME...
Old Nov 10, 2009 | 02:22 PM
doy's Avatar
doy
Thanks xero. Where is the filter located? Thanks.
doy
Old Nov 11, 2009 | 04:45 AM
xero_xero's Avatar
It depends on what year you are referring...
Old Nov 12, 2009 | 03:27 PM
doy's Avatar
doy
2001 Civic LX
kenji51590
Feb 24, 2011 05:24 PM
hazo vti
Jul 13, 2006 05:59 PM
JDMracer00
Aug 27, 2005 12:43 PM
xllybx
Jul 8, 2004 09:20 PM
CanadianCivic
May 2, 2004 07:34 PM
