d16y7/y8 mini me surge
Old Mar 22, 2009 | 07:51 AM
Okay, sorry about that... you saying it didn't increase idle speed made it sound like you were disagreeing
I was informing Trust that the PCV system does not function to control idle speed. It just so happens that the PCV system uses IM vacuum to perform its function (reduce emissions). A leak in any system that uses IM vacuum may increase engine idle speed. This does not mean that such systems function in idle speed control. For example, if you disconnect the cruise control vacuum hose, the engine idle speed will increase due to a higher amount of air flowing into the IM. Clearly, the cruise control is not part of the idle control system. By contrast, the IACV and FITV do control idle speed by specifically regulating the amount air allowed to bypass the throttle body into the IM.
Old Mar 22, 2009 | 12:13 PM
bonziimitch's Avatar
ive checked all vacuum line, throttle and IM. i checked the PCV and it was bad, changed it and helped a lil. still surging in idle from 900 to 2200 rpm. i think it might be the IACV so i went and ordered one today and it will be here tomarrow morning.all hoses are brand new and hooked up correctly. went driving with load on engine, it does not surge.
thank you for ur guys help by the way...
Old Mar 22, 2009 | 12:14 PM
And stu, all the pcv system does is get the blow-by gasses out of the crank-case.
i got that memo like 8 hours ago, bud
Old Mar 22, 2009 | 04:32 PM
smarta**
to the OP, that's exactly what my friend's ej2 was doing; with the new IACV (his was the FITV), it should idle fine again.
Old Mar 22, 2009 | 05:33 PM
Originally Posted by bonziimitch
...still surging in idle from 900 to 2200 rpm. i think it might be the IACV so i went and ordered one today and it will be here tomarrow morning.
Why not try cleaning the IACV before buying ($$$) a new one? Cleaning the IACV often leads to a fix. Have you also tried bleeding the cooling system?
Old Mar 23, 2009 | 03:44 PM
well i found it. it was the EVAP. idles perfect now. thanks for ur guys help
Old Mar 23, 2009 | 03:49 PM
Congrats. Disconnected or broken EVAP vacuum hose?
Old Apr 13, 2009 | 08:15 AM
hing75's Avatar
Hey sorry to butt in fellas but i just wanted to know about the D16y8 head.
Someone is selling this vtech head and saying something about vtech cams being manual or automatic?What's that about? I have a DX coupe with the D16y7 engine btw.
Old Apr 13, 2009 | 12:47 PM
that's untrue. do not buy anything from someone who says that... they don't know what they are talking about and whenever they were using the engine they probably didn't know what they were doing.
P.S. it's VTEC.
Old Apr 14, 2009 | 02:31 PM
hing75's Avatar
P.S. it's VTEC.
Hey thanks alot!!! You've just saved me from being extremely pissed with myself for being taken in!
dstig1
Oct 21, 2014 07:29 PM
Aaron A Archer
Dec 4, 2011 05:30 AM
Aaron A Archer
Dec 3, 2011 03:38 PM
kellypark
Jun 14, 2011 08:09 AM
Drows
Dec 20, 2006 01:09 PM
