remove alternator stuck
Old Oct 24, 2009 | 09:55 AM
brucey's Avatar
ok bad news
the car in a garage and he removed the bolt finally....
the alternator have been changed and still get same problem
alt is giving 12 volt reading.... should it read 14 or 13.50 volt depend of the manufacturer (cant spell right)
i m suspected it is wire defection meaning alt didnt feed to battery
am i right ?
Old Oct 24, 2009 | 03:01 PM
brucey's Avatar
i did try to delete edit but cant ?
tell me how to delete post that i posted twice by mistake
please
thank you
Old Oct 25, 2009 | 03:06 AM
brucey's Avatar
there is no more reply ?
Old Oct 25, 2009 | 07:39 AM
plasticman's Avatar
Hi.
Is everything working now? I saw there was no more replies. What's happening with the car now?
I'm sorry I'm jumping into this thread late but I just finished this repair myself.
Old Oct 25, 2009 | 05:36 PM
If it is a 1996, 1997, or 1998 model, consider the "fuse 15 problem". The wires behind the engine get frayed and short out, then the alternator will not power up and charge the battery. Fuse #15 under the dashboard is usually blown.
Check that there is battery voltage on the large wire to the screw terminal on the alternator. This wire is live all the time even with the key off. Attempting to replace the alternator without following proper procedure and disconnecting the battery first-- often leads to shorting this wire to ground and blowing the main fuse. Then (if the car doesn't end up completely dead) the new alternator will not work.
Old Oct 28, 2009 | 01:21 PM
brucey's Avatar
yep it is fuse
solved
thanks guys :-) sorry for delay
TPRCIVIC
Feb 2, 2014 01:38 PM
frankumar
Jul 26, 2011 04:49 PM
grunge
Sep 24, 2006 09:00 PM
Cappelle
May 18, 2005 09:52 PM
cheffsez
May 11, 2005 07:35 PM
