96' Civic ECU Error Code 1
Old Apr 26, 2010 | 11:56 AM
running riot's Avatar
Originally Posted by Ska-T
Thanks guys. The job is done. MIL is reset and hasn't come back on ... yet.
In case some beginner reads this later here are a few details not mentioned in the above posts. After the OBD II scan showed an error code of P0135, the electrical troubleshooting shown in the Honda Service Manual p. 11-157 was followed. My sensor had infinite resistance between terminals 3 and 4, thus it had to be replaced. I "borrowed" the oxygen sensor socket set from Autozone. That is, you buy the tool, but when you return it you get your money back. They give you 90 days to return it. Great program. Too bad the OBD II scanner is no longer included among their loaners tools in California (verified by Autozone). The car repair lobby didn't like it and our governor agreed with them. I took off the oxygen sensor cover (p. 9-12). It may not have been necessary, but it made it easier to use my socket wrench. Denso 234-4099 did not require any splicing of wires. Denso included a tube of anti-seize grease, which was nice. I used it on the sensor threads as well as the bolt threads for the cover.
Regarding reading ECU error codes via the Service Check Connector (p. 11-81), if I'm not mistaken the MIL flash is actually indicated when the light goes off. That is, the MIL goes from on to off to back on. The duration that it is off indicates whether that digit is a one or a ten. My MIL flashed off once very briefly (seemed like less than 1/2 second) indicating an ECU error code of 01 (not 10), and that was later confirmed by the OBD II code of P0135.
Any recommendations for an inexpensive OBD II scanner? I read that CAN scanners are required for newer cars. Is CAN backward compatible to a '96 Civic?
just thought i would throw in my .02. I juts recently finished a swap and am throwing those codes (and a "missing" catalytic code) and from my experience, those codes will pop up if you have a ground issue. In those model years, there are wires that run under the manifold that sometimes rub and either ground or strip or get cut. The IACV IAT O2 and other sensors all ground to the same places. There is a ground point on the thermostat housing and and another to the transmission. If the ground on the O2 sensor is incorrectly wired or not making proper connection, it can cause those codes to occur.
Thought maybe that would be pertinent. If not it will show up in search results. g'day.
Ghettochild_2600
Apr 14, 2014 11:49 AM
brianjason
Jul 28, 2013 08:59 AM
JAB1986
19
Mar 10, 2012 07:33 PM
nightrider46
May 21, 2007 04:21 PM
sirach38
Jun 19, 2004 10:35 PM
