1995 civic
Old Aug 18, 2009 | 08:54 AM
  #221
FRZ's Avatar
FRZ
Originally Posted by jwmm04
Don't re-use the head gasket. If you have taken the head off, regardless of what the condition of the head gasket looks like, you will need to replace it.
I did replace the head gasket, I was just wondering what the bad one suppose to look like. One thing I didn't replace is the timing belt. The new one did not fit. It is slightly smaller and I couldn't get it to fit. The old one still look decent, I checked it.
Old Sep 1, 2009 | 08:49 AM
  #222
FRZ's Avatar
FRZ
I am officially done installing all the parts that I wanted to replace, except for the catalytic converter and the timing belt. The cat I left out cause I don't want to get stop and ticketed and the timing belt did not fit and I felt that the old one was still in good shape by inspecting it. Now all I have to is get the car to start.
I don't know if it was from before I changed the head gasket when I was cleaning out the coolant with water and the water was getting in the engine or something else but I don't feel like engine is cranking, only the alternator. So what gives?
Old Sep 1, 2009 | 09:46 AM
  #223
is it turning over? are you getting spark? is your fuel pump turning on?
Old Sep 1, 2009 | 12:24 PM
  #224
FRZ's Avatar
FRZ
Well, I can't test the sparks right now without someone to turn the key on for me. I do hear the gas pump when I turn the key. Now as for the car turning over, I can't be sure.
Old Sep 1, 2009 | 12:29 PM
  #225
when you try to start it does the motor turn over???? does it try to start..
what exactly is it doing? have you rechecked all your wires,plugs,grounds,fusues ??
Old Sep 3, 2009 | 03:00 PM
  #226
FRZ's Avatar
FRZ
No, the motor doesn't sound like its trying to start, just the alternator that turns.
gtp2nv
Sep 1, 2008 02:23 AM
limerence
Nov 17, 2007 10:59 AM
mr honda
Aug 25, 2007 09:31 PM
teler86
May 26, 2004 05:31 PM
teler86
May 23, 2004 03:35 AM
