1995 civic
You know I was thinking about that but, now I don't know how I am gonna take that out because the bolt's head is all messed up. Even the intake manifold is giving me grief. I have to take it out to do my head gasket. All these rusty bolts in tight places are a nuisance.
I am gonna have to saw off these rusted screws, the one holding the alternator and the ones holding the catalytic converter. The old header, the downpipe and the catalytic converter might have as well being welded together because the screws and bolts holding these parts are so rusted they are like one piece.
Won't I be able to rent one of these saw guns from either autozone or lowes are something?
Ok. Header is out. I saw the screws connecting the downpipe catalytic converter. Now for the alternator and then on the crankshaft pulley bolt. I know I've heard that there is special tool to remove the crankshaft pulley bolt, well, I don't have it so any suggestions on other method I could use? Then I can be set. I can replace all parts that's been sitting there.
I finally decided and got an impact wrench. I found an electrical one at the autozone and I also brought a close cut hack saw. The pulley bolt is out and the alternator adjusting bolt is about 1/3 cut. That one is a little tough being in a tight spot but, I will get it completely eventually and drill out the rest of the screw from there.
got the head off. I don't see any crack in the head gasket. How do I know if its blown. And how do I drain the coolant out of the block?
Edit: I also removed the water pump and doesn't look damage either, look exactly like the new one that I am replacing it with. how do i know if this one is bad too?
Almost done. All I have left to do is bolt on the down pipe to the catalytic converter. I need to get the two bolts that connect them, one bolt for the distributor and cross my fingers and hope everything was bolted back good enough.
