94' starts, rough noise/idle
Old May 29, 2010 | 05:50 PM
  #21
Mecca8383's Avatar
Originally Posted by Sbtflip
Aight, got a new problem. After finding out that putting pressure on the timing belt cover that the sound would change for the better from what i can tell. Tried taking it off. But it catches onto the valve cover. So took out spark plug things, unscrewed the valve cover and took it off to get the cover of the timing belt off.
Trying to check the timing belt if the cover was off, but now the car wont start.
So put everything back to way it was and still it wont start.
Question.....When you took the valve cover off and the timing cover..What was left off when you tried to start your civic?
If you only left the timing belt cover off & everything else was on...Did you make sure you connected the grounding wire to the valve cover from the body?(should be somewhere near the driver's side headlight I believe..maybe closer to the AC fan)
I'm no mechanic but the cranking without starting happened to me before when i forgot to connect the ground wire from the body to the valve cover & an co-worker at work(who been a mechanic for 25 years) told me if that ground wire is not attached to the valve cover then it can fry your ICM or even your coil.
But of course..that's just my car...
Old May 29, 2010 | 07:21 PM
  #22
Sbtflip's Avatar
First time only thing left off was timing belt cover. Then it didnt start, so put everything back. But yes did forget the grounding wire but only for like 3 tries till realizing it, so wouldnt think it would **** over coil that fast. and ICM is?
Old May 29, 2010 | 07:46 PM
  #23
SilverSedan's Avatar
I don't know what an ICM. I know what an ICBM is, but nothing honda related :P I think he means ECM. Electronic Control Module, or basically the computer that runs your car.
Old May 30, 2010 | 07:31 AM
  #24
Mecca8383's Avatar
Ignition Control Module...sorry..
Old Jun 1, 2010 | 12:39 PM
  #25
Sbtflip's Avatar
Originally Posted by mk378
Take the distributor cap off and check that the distributor shaft rotates when you crank, if not, the timing belt has failed.
Finally got the chance to look at it this morning. And yes it does rotate when cranking.
Unanswered question: Can an aftermarket alarm prevent a spark? And if so is there a way to trace it be the reason.
Mecca8383
Mar 31, 2014 05:15 AM
HondaLips137
Oct 8, 2013 03:40 PM
dailydriver
Sep 16, 2013 06:08 AM
Stumasters
Jan 20, 2008 12:58 PM
mysi
Aug 10, 2007 06:51 PM
