Got $200 today. What shall i get?
Old Sep 16, 2004 | 08:46 PM
dalifts's Avatar
Default Got $200 today. What shall i get?
got 200 from work on the side today. What mod should i get?
gota 89 honda dx hb, 1.5 liter 5 speed tranny, painted valve cover, new wires(stock tho). Full catbac excaust. thats all right now. Let ne know what i should get
Old Sep 16, 2004 | 11:20 PM
Default RE: Got $200 today. What shall i get?
i have to say, your motor needs all the help it can get. for the cost of rebuilding it, you could geta newer sohc vtec engine, probably for the same amount of $$$
Old Sep 16, 2004 | 11:56 PM
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Old Sep 17, 2004 | 10:18 AM
dalifts's Avatar
WHat year vtech should i look for and how much do they run
Old Sep 17, 2004 | 10:38 AM
Wheelbroker's Avatar
We'll let's see here...
How about some new Nippon Iridium Spark Plugs to start with..only cost you about $12.99 each... then how about a new set of wires by Vi-Tech at about $165.00 for 4 wires..
Not much left to spend now, so go fill your tank and your done already...
Wheelbroker/Ang[sm=smiley20.gif]
Old Sep 17, 2004 | 11:06 AM
you can use your stock tranny ( 88-91 si trans would be better though) so just get the complete motor and ecu out of a 92-95 civic (d16z6) which is obd1 or out of a 96-00 civic(d16y8) these should be out of an ex or si. dont be tempted by the d15z1 out of the 92-95 vx, or the 96-00 hx (not sure of the engine code, im sure someone here knows it.) its a super gas-saver versin of vtec. go with the z6 or y8. the z6 is probably a little easier, and definately a little cheaper. but the y8 is a little better, due to the combustion chamber design, and has less miles. check ebay and see if anyone is close enough to drive and pick it up, as shipping will cost almost as much as the motor. also check out thepartstrader.com you can search for stuff close to you.
Old Sep 18, 2004 | 08:15 AM
polo708's Avatar
you cant go wrong with an intake... that would be my buy.
civic 786
Jan 27, 2008 06:24 AM
classiccarsrule85
May 3, 2007 02:57 PM
Pete
Sep 24, 2006 09:54 PM
charly
Jun 17, 2006 11:02 PM
