need advice on future swap
Old Jan 15, 2006 | 04:43 PM
ssteve's Avatar
Default need advice on future swap
I just bought a 1990 civic , its a base model 4sp with no options. My plans are just to drive it and auto X it, so I dont need a lot of power I just want a cheap easy swap with a 5sp and some potential for future modding. I dont know a whole lot about honda (FF stuff) so can you please give me a suggestion on what would be the best bet for a small amount of cash.
Old Jan 15, 2006 | 07:57 PM
Kappa22's Avatar
Default RE: need advice on future swap
Well, the best bang for the buck would probably be a DOHC ZC, which is rated at 130 hp (roughly double what your car has). It will bolt up to the mounts and tranny, but it requires a DPFI to MPFI conversion (there is a write-up available in the DIY section) and a different ECU. The best part is it shouldn't cost you more than $700.
For autocross, I would say maybe go with a B16A1. It's a very inexpensive swap for the amount of gain you would get (close to 100 hp) and again, it will bolt in. It does require a different tranny, axles, a few cables, ECU, VTEC wiring, as well as the MPFI conversion, so there will be extra costs associated with the installation.
Old Jan 16, 2006 | 02:13 PM
ssteve's Avatar
I have a friend that has a motor out of a 89 or 90 si with the tranny, wiring harness. would it be worth $200 for everything, and would it be a direct swap?
Old Jan 16, 2006 | 06:00 PM
ef4life's Avatar
yes it would be worth it for the price, power wise a d16a6 from a 90-91 si only made 116hp your car i think had like 75hp. it would be a very noticable difference, especially with intake, header, and exhaust. it should drop right in but you will probably need the 5spd shift linkage. and will have to wire up mpfi.
hellcomer52
Oct 14, 2012 03:03 PM
vmf
Mar 10, 2008 10:11 AM
skimmy_jimmy
Mar 8, 2008 04:54 PM
07LXc71341
Feb 20, 2008 09:33 AM
jhsplaya08
14
Sep 18, 2005 05:37 AM
