planning on doing engine swap in the future
Old Mar 9, 2008 | 10:00 AM
vmf's Avatar
vmf
Default planning on doing engine swap in the future
Hey guys, just doing a preliminary research now. i have a 2001 LX coupe and i really dislike lack of power the stock engine produces.
as far as i know there is not much i can do squeeze more out of it so i was thinking about swapping, so far ive heard about RSX engines and accord engines.
i want to put a 6 speed manual tranny from RSX as well. the question is: RSX engine and tranny, are they direct bolt on? how bout accord engine? do i have to change ECU? will my instrument cluster work?
any info would be appreciated.
Old Mar 9, 2008 | 08:12 PM
cyberx32's Avatar
Default RE: planning on doing engine swap in the future
dont know too much about that, but i do know that you have to change to a k series engine (which the rsx has.
Old Mar 9, 2008 | 09:05 PM
jpnolan's Avatar
the k series are the only engines that will fit use the search at the top of the page no it is not a direct bolt in ive hear the radiator support needs to be cut although i could be wrong
Old Mar 10, 2008 | 09:16 AM
vmf's Avatar
vmf
will my instrument cluster work with new engine and ECU if ECU has to be swapped?
Old Mar 10, 2008 | 10:11 AM
FlipHKD720's Avatar
ECU for sure has to be swapped. Check out THIS WEBSITE. It has some of the best K series swap info i've seen.
hellcomer52
Oct 14, 2012 03:03 PM
miguelv
EG Swaps
Jan 23, 2012 06:39 AM
badboy4life
Sep 1, 2007 08:28 AM
ivtec
May 5, 2007 02:22 PM
asttak
EK Swaps
13
May 4, 2007 12:58 AM
