Swapping ECU's
Old Nov 16, 2004 | 12:19 PM
dmsteele92831's Avatar
Default Swapping ECU's
Ok I have a 97 HX which uses the P2N ECU. The way the HX works (for those that don't know) is that it runs off of 12 valves until it hits 3100 rpms the the vtec-e kicks in and it runs off of 16 valves. (Great for gas mileage) If I get a Skunk 2 chipped P28 ecu and swap it with the P2N ECU, it puts the vtec at 4,800 rpm's. My question is will it not even work on my car? Is there a way to adjust the vtec-e in the ecu? Or could I get the ecu then buy a separate vtec controller to adjust the vtec setting?
Old Nov 16, 2004 | 12:57 PM
niteryder's Avatar
Default RE: Swapping ECU's
if u want to control the vtec, look at the apexi AFC. or jus get a programable ecu form hondata.
Old Nov 16, 2004 | 01:03 PM
I don't want to change the vtec setting I want to keep it at 3100 rpms (only 12 valves up to 4,800 rpms...ouch) while changing out my ecu to a chipped one. I've heard good things about the apexi controller, plus they look sweet but a standard vtec controller would do the job if thats the route I go
Old Nov 16, 2004 | 06:57 PM
put on the ex head too, problem solved
Old Jul 23, 2005 | 09:44 PM
trevorb05's Avatar
hi i also have a civic hx but mines a 00....please let me know how your ecu swap goes cause im looking at doing the same thing
Old Jul 25, 2005 | 10:18 PM
blackeyes's Avatar
if you swap the ecu, the way the engine performs is going to change. vtec, valves used, fuel, everything. do you want more power?
ivychick22
EK Swaps
Aug 17, 2005 07:33 AM
95dx28
Jun 14, 2005 08:29 PM
ilinihonda
Apr 18, 2005 05:37 PM
terboracer
EK Swaps
Jan 16, 2005 07:39 AM
dalifts
Nov 15, 2004 08:59 PM
