I know nothing about swapping engines
If i was going to get an engine swap for my 95 dx 4d auto (D15B7), what should i do and which engine should i choose? Where could i get it from and about how much would it be? Any info helps.
Start here Swap Info (Sticky) and then go to "EG Swaps" and start reading.
But if you need instant gratification the most popular would probably be to swap the V-Tec head on to your block, aka the "mini-me." It essentially gives you a V-Tec motor with higher compression, so ~ 125-130 HP. A bigger and better swap would be to go to the B16 DOHC V-Tec. I think that one is ~ 160 HP. There's a ton of info about swaps on here. Just poke around. Good luck.
This is a great write up. Mini Me Conversion
There is a link in that write up to the original post with pics and everything.
