EG Swaps 1992-1995 Civics
ZC Swap for 92 Civic HB
Old Feb 6, 2006 | 01:38 PM
Djohnsto's Avatar
Default ZC Swap for 92 Civic HB
Well I want to swap from stock 1.5 SOHC 16v non-vtec out of my car for the ZC 1.6 DOHC non-vtec and build that. I have the need for speed and i figured out that building and turboing the ZC would most likely be cheaper to for-fill my need or want. Will I be able to use the same wire harness and computer in this swap?
Old Feb 6, 2006 | 06:17 PM
ef4life's Avatar
Default RE: ZC Swap for 92 Civic HB
i don't believe there is a dohc zc motor that is obd1.
but if your going to build a good turbo motor you could stick with your 1.5 add new pistons and rods, swap a z6 head on it, wire up vtec, get a p28 and hondata or another engine management system, and then turbo it and enjoy a good relatively cheap build(compared to buying another engine and doing the same)
Old Feb 8, 2006 | 12:44 PM
Djohnsto's Avatar
Really.....I see on ebay that they have a few of the ZC engines and that are for the 92-95 civic's. That is what brought this swap to my attention. My engine has 160,xxx so id like to swap rather then just doing a mini-turbo.
http://cgi.ebay.com/ebaymotors/JDM-Z...34595998QQrdZ1
Old Feb 8, 2006 | 01:20 PM
ef4life's Avatar
well, i guess there is a zc for obd1, and since its non-vtec you should be able to use the same harness, but you will need the zc ecu
Old Feb 8, 2006 | 01:27 PM
Djohnsto's Avatar
Aight cool...the harness was the only thing i was really worried about.
Old Feb 8, 2006 | 01:45 PM
ef4life's Avatar
there might be a little thing to add with the second cam, but i never messed with any dual cam stuff really
Old Feb 10, 2006 | 08:47 PM
Djohnsto's Avatar
I didnt think the second cam would really have anything to do with computer.
Old Apr 17, 2006 | 11:12 AM
Crook_EG8's Avatar
i did a ZC into an 89 Si, and got a greddy turbo for it and ProfecII boost controller, i ran a 12.5 @ 1.8 bar of boost, gettin reddy to put that engine in my EG in a few weeks
Old Apr 17, 2006 | 02:55 PM
Kappa22's Avatar
The 92-95 ZC's are identifiable by their brown dizzy plugs.
hydro_yang
Sep 12, 2009 01:18 PM
taintedsaint
EG Swaps
May 16, 2008 04:46 AM
WhiteCivic15
Jul 7, 2006 03:17 PM
00civicEX_3
EK Swaps
Feb 26, 2006 11:08 PM
nemesis08
Jun 8, 2005 08:05 PM
