89 civc DX
Old Mar 19, 2006 | 09:24 PM
DanHarrington15's Avatar
Default 89 civc DX
Hey yall.. 1989 DX here.. thinking about swap if I keep the Civ... suggestions.. comments.. anything would be appreciated thanks!
Old Mar 29, 2006 | 10:11 PM
b8teen's Avatar
Default RE: 89 civc DX
I have a 91 hb dx and i was in your shoes. i recently did a zc sohc swap in my car. its not the most performence motor out there, but the swap is noticable. im looking into better options now, but the zc sohc is the most easy swap. the only thing you have to convert is the dpfi to mpfi. and that involves the fuel injector resister box, and a couple of wires added to your dizzy and ecu. othe rthan that, do a search and find out what you can do with it.
hope it helps
mike
Old Mar 30, 2006 | 10:16 AM
finalimpact's Avatar
hell just doing the mpfi conversion you will notice gains such as better throttle response, quicker reving, stronger powerband. if money is tight id recomend this. either way when you do eventually figure out if you want to swap to b-series or the such, your already mpfi converted. question is what are you planning on swapping and what are your power goals?
Old Mar 30, 2006 | 01:36 PM
Kappa22's Avatar
Actually the DOHC ZC swap is easier than the SOHC, since you don't have to run any VTEC wiring. But yeah, for the price, either one is hard to beat if you're just looking for a nice reasonable jump in performance.
Old Aug 8, 2006 | 05:51 PM
89_hatch559's Avatar
hey do u know what swap can i do into my civic and still pass smog?
Old Aug 8, 2006 | 09:11 PM
Plazma's Avatar
swap a b16 or a b18c, im buildin a turbo b16 right now for my 89 DX
travhdg08
Apr 23, 2006 11:00 PM
seadoohx
Jan 5, 2006 08:03 PM
mahmi
Sep 6, 2005 05:44 PM
adamwest
Aug 18, 2005 11:25 PM
nutty696
May 20, 2005 01:31 PM
