Tell me how to install headers!!!
Old Mar 22, 2006 | 07:42 PM
Spark's Avatar
Default Tell me how to install headers!!!
well i just picked up some megan headers today...and i know they are pretty much bolt on but i just wanted to make sure. cause some guy was mentioning something about a O2 something or other. and i don't want to mess it up. or....and i was wondering if they were legal or not....i'm going to put them on regardless.
Old Mar 22, 2006 | 07:48 PM
Pete's Avatar
Default RE: Tell me how to install headers!!!
Take the stock exhaust manifold off, remove the 02 sensor. Put the 02 sensor in the new exhaust manifold, bolt it back on but use a torque wrench. Tighten it to honda specs. Use the old gasket, dont get a new one.
Old Mar 22, 2006 | 08:04 PM
Spark's Avatar
and that's it right? cool deal.....hopefully i'll have time to do it tonight. thanks a lot.
Old Mar 23, 2006 | 09:38 AM
rit14623's Avatar
I've done exhaust replacements but never a header. Is there a certain order you are to torque down the bolts?
Old Mar 23, 2006 | 09:54 AM
polo708's Avatar
start from the middle and work your way out... that will get you the best seal. The o2 sensor should "clip in" some where close to teh block.
install:
1. Just find the o2 sensor which is sticking out of the header (exhaust maniflod) and follow the wires to where it ends. Disconnect that from the clip.
2. Go under the car and disconnect the midpipe from the header
3. Disconnect the header from the block.
4. Remove the o2 sensor from the header.
5. Install o2 sensor in new header
6. Connect the new header to the block (tighten from inside out)
7. Connect midpipe to header
8. Reconnect o2 sensor harness back to the car.
is it legal? Probably not, unless its a DC Sports header. They always seem to have CARB legal headers. Most of your off brand and ebay headers are not CARB approved.
Old Mar 23, 2006 | 12:15 PM
itsmeek's Avatar
what pole said..it's very straightforward bro, just get in there and you will realize it's not all that complicated.
Old Mar 23, 2006 | 03:18 PM
Nail I3unny's Avatar
i was gunna say wouldnt it e easier to take out and re-install the o2 sensor first?
Old Mar 23, 2006 | 09:46 PM
Spark's Avatar
have a problem.....one of the bolts the connect the header to the midpipe is stipped!!! what is the best way to get this out?!? cause i've come to a stand still with this.
Old Mar 23, 2006 | 09:56 PM
id have to say the best way to get it out is to cut it...but im not sure.
Old Mar 23, 2006 | 10:04 PM
Spark's Avatar
yea that's what i was thinking....if no one else has any other way i'm just going to do that.
