check engine light
Old Dec 16, 2004 | 12:32 PM
kevin121987's Avatar
Default check engine light
i have a 94 honda civic ex.. enging light on.. shows code 5. map sensor.. new map.. swapped computer.. check voltage at sensor at computer.. check continuity on all three wires.. everything checks out like it should.. can not clear code.. come on after engine runs about 4 seconds. and stays on.. anyone out there have that before... any suggestions? shop looked at it and shrugged too.... help.
Old Dec 20, 2004 | 04:12 AM
Glitch's Avatar
Default RE: check engine light
disconnect the battery wait 30 seconds reconnect if it continues make friends with a tech at a shop.
Old Dec 20, 2004 | 12:30 PM
94solchick's Avatar
check your knock sensor. My boyfriend's car threw out the same code, and it turned out to be the knock sensor. Test it, it won't hurt.
Old Dec 20, 2004 | 06:45 PM
Vovka86's Avatar
If you fixed the problem you have to reset the computer Glitch said disconect the battery for a few seconds.
otherwise the check engine light is going to turn on even the problem is fixed.
Old Dec 20, 2004 | 07:35 PM
andryuha's Avatar
I don't get it, you don't know what the problem is? Just go to the nearest autozone, and ask them to test it, they will tell you what's wrong. Also note, that sometimes a single problem could trip several codes, so don't fix everything at once. On my Jetta, the check engine came on, and it showed misfires in 3/4 cylinders, and a bad O2 sensor. So I changed the plugs and wires, but the check engine light stayed on. I disconnected the battery for about 10min, and it went away - no more codes either. So after you fix something that activates your check engine light, follow Vovka86s advice.
Old Dec 21, 2004 | 10:45 PM
i take out the fuse to the ecu, or unplug it if its out, then let it sit w/o power for 20-30 minutes (i havent tried it in less time, so i know that long works.) that way you dont have to reprogram the radio and clock and all that every time.
miguel11691
Nov 15, 2015 08:11 PM
Rool_908
Jan 3, 2012 07:03 AM
mhlden
Oct 2, 2011 07:14 AM
towelie
Aug 30, 2010 05:08 PM
Benny Sim
Jul 19, 2005 07:43 PM
