Viper 5000 Alarm
Old Apr 17, 2006 | 09:58 PM
coolguy1234's Avatar
Default Viper 5000 Alarm
Hi i got a viper 5000 alarm installed in my 95 civic and i braught the car home and took the battery out of it. After putting the battery back in i discovered that the alarm did not work at all. Also installed was acctuators which lock and unlock my doors they also do not work now. I tryed pulling out the fuse and putting it back it it did not work. It is not in valet mode either. also the key pad beeps like it is out of range. What do u think it is. ( If u think i have to reprogram the key pad what do i do).
Thx josh
Old Apr 18, 2006 | 10:49 AM
mill$civic's Avatar
Default RE: Viper 5000 Alarm
humm i have the same alarm..i took my battery out the other day and when i put it in everything was fine, i would call the guy who installed it
Old Apr 18, 2006 | 07:49 PM
jhsplaya08's Avatar
i have the same alarm. i put an optima yellowtop in after i got mine and it worked fine. since then i have unhooked it once. everything still workin good....maybe you disconnected a wire or something that should have been hooked up. i dunno im with mill$civic here....call or take it to somebody
Old Apr 19, 2006 | 12:54 AM
bakinwagin's Avatar
From: transplanted to the land of the Wild & Wonderful
Hey I have a 791XV.... When my keypad is out of range it beeps like two or three times and flashes an arrow at the top of the display. It will also do this if the alarm brain is not getting power (if your ground is loose it won't work either), you might also check to see if the antenna wire is still connected at the box and at the antennae...Check those connections and the fuses... If no luck, call the installer!
Karado58
Oct 4, 2009 04:26 PM
mill$civic
Dec 16, 2005 09:49 PM
jhsplaya08
Jul 27, 2005 08:28 PM
jhsplaya08
Jun 23, 2005 05:42 PM
Mikedg186
May 15, 2005 07:31 PM
