whats the deal?
Old May 1, 2006 | 09:34 PM
jsoSoCal's Avatar
Default whats the deal?
Ive noticed that when Im shifting fast, Like from 2nd to 3rd the tranny will grind. Its like the clutch isnt engaging in time, Is this normal or is my clutch going bad? what are common symptoms of a bad clutch. My car is a 94 gsr if that helps
Old May 2, 2006 | 02:50 PM
jwsimons's Avatar
Default RE: whats the deal?
technique... try double clutching.. or rev matching to help align the synchros
Old May 2, 2006 | 03:33 PM
riceburner700's Avatar
if your clutch is going out then usualy you can notice it start in the higher gears, like say you get up into 5th gear and start to give it gas, the motor will wind up but the car will feel like its slipping and not grabbing like it should be.... sounds like your throw out bearing could not be fully engaging the clutch so it is kind of like half engaged and trying to put it into gear which is bad because it will grind..
tano001
Jul 28, 2008 04:21 PM
Civic Si 00
Dec 26, 2007 04:02 PM
TBH_u_sw0ll0w
Nov 12, 2007 10:43 AM
DreamTeam87
Oct 9, 2007 12:32 PM
96civic285whp
Sep 19, 2006 08:32 PM
