whats the best swap for a 1989 si?
Old May 12, 2006 | 02:52 PM
mongochuy's Avatar
Default whats the best swap for a 1989 si?
hey i just want some info. on what swap would be the best for the 1989 si. i was looking toward the h22 or the b18c5. but i have read that one is better than the other. what should i go for? THX for the info.
Old May 13, 2006 | 01:46 PM
yorky's Avatar
Default RE: whats the best swap for a 1989 si?
b16 all day
Old Jun 4, 2006 | 05:27 PM
ef4life's Avatar
the h22 is a hard engine to fit and is costly because of all the parts you need. a b18c5 would be the way to go, but it will cost a lot also, but a much easier swap to do.
Old Jun 5, 2006 | 10:47 PM
finalimpact's Avatar
h22........once its in and running its still cheaper than a type r swap, makes more power and has a broader power band. but for the cost of either you can build your si engine and turbo it then run circles around the h22 and c5 assuming you do the work yourself.
Old Jan 9, 2007 | 12:33 PM
Powermidget's Avatar
both of those are going to require some custom fab...id go b16 gsr or ls to simplify your life and with the extra money boost that bitch
Old Jan 9, 2007 | 12:42 PM
ef4life's Avatar
thread from the dead man, and a b18c5 type r is the same size and mounts as a b16 or gsr, so there would be no custom fab work.
Old Jan 9, 2007 | 05:57 PM
ORIGINAL: ef4life
pshhhh custom beating of the frame rail with a hammer FTW!!
ex civic
EP Swaps
Apr 16, 2022 12:51 PM
MyCivicBroke
Aug 4, 2007 07:49 AM
KoDKingVegeta
ED-EF Swaps
Dec 29, 2006 08:25 PM
89crx
Sep 10, 2005 09:24 AM
maddstylez
EG Swaps
Dec 31, 2004 01:30 AM
