brake wear
Old May 13, 2006 | 07:02 PM
xe1002's Avatar
Default brake wear
after growing tired of hearing my brakes squeal, i decided to replace the pads last night. after removing the old ones, i noticed that both pads for each side were wearing uneven. i was just curious as to what would cause this. they were the original pads from honda. also, i had noticed a sort of grinding sound coming from the right front whenever i would turn slightly and brake at the same time...dunno if that could have anything to do with it. any input is appreciated!
Old May 13, 2006 | 07:16 PM
mxs's Avatar
mxs
Default RE: brake wear
Could be a wheel bearing? A shop told me that was the reason my rotors were wearing unevenly . . . it's a possibility.
How many miles are on your car?
Old May 13, 2006 | 07:18 PM
AgentofDarkness's Avatar
If the wheel bearings are bad, whenever you go over 30MPH you will hear an abnormal noise from the wheel. I don't get how a bad wheel bearing could cause uneven pad wear, some1 wanna explain that?
Old May 13, 2006 | 08:57 PM
mxs's Avatar
mxs
now that I think about it . . . I don't know.
Did you regrease the caliper pins? They should both be sliding smoothly. If not, that could cause the pads to wear unevenly
Old May 13, 2006 | 11:31 PM
xe1002's Avatar
didn't regrease the pins...
my car just turned over 61k. both sides wore the same way: the inside pad wore at a slant and the outside pad wore at the opposite slant....if that makes any sense. i figure i'll give the new pads a little bit of wear and then remove them to see if they are uneven too.
civic2001
Jan 3, 2015 10:55 AM
D16z6
Feb 11, 2006 01:33 AM
sanchez
Sep 2, 2005 09:41 AM
gunmetal
Jul 29, 2005 05:16 AM
willatter
May 27, 2005 07:42 PM
