1992 Civic ELD
Old Jan 6, 2005 | 05:40 PM
ebc's Avatar
ebc
Default 1992 Civic ELD
Can anyone tell me how to find the Electronic Load Detector in a 1992 Civic? It sure doesn't seem to be in the same place as the picture in the Haynes manual.
Thanks in advance
Old Jan 6, 2005 | 06:23 PM
fast97's Avatar
Default RE: 1992 Civic ELD
what is the problem?
Old Jan 6, 2005 | 09:09 PM
ebc's Avatar
ebc
It all began with the insrtument lights flashing when I hit the brake. Then, the speedometer would drop everytime the brakes were pressed...then the speedometer died completely and the car became nearly undrivable. It will idle fine, but will not accellerate. In addition, if I try to use anything electric at all it will kill the engine. I replaced the alternator a couple of months ago so I am assuming that is not the problem. I looked in Haynes and my symptoms seem to fit a malfunctioning ELD... poor divability and elec. problems. Any suggestions are welcome.
Old Jan 8, 2005 | 08:06 PM
fast97's Avatar
Well i had a simalar problem in my 97 HX and the problem was five bad alternators and one bad fuse. The fuse was an sp sensor fuse. Did you find the eld if so check it with a volt meter as it says in the haynes manual. When i had this problem mine tested fine. I spent like $700.00 tryin to find out what my problem was I was mad as hell when my buddy found that blown fuse and everything was fine and still has been ever since then except for junk alternators.
Old Jan 8, 2005 | 09:30 PM
XCM828's Avatar
ORIGINAL: fast97
Dang dude that sucks. At least you didn't have to spend $700 more when you found the problem.
Old Jan 8, 2005 | 10:50 PM
ebc's Avatar
ebc
Thanks for the help. I had some time to mess with it today and found a solution. The cable that links the battery and the alternator corroded. It was covered by insulation so I didn't see it. All the other (electical) problems were side effects from the low voltage of the battery throwing the computer off. I had a great education on tracking through the electrical system.
Old Jan 10, 2005 | 06:46 PM
fast97's Avatar
Well thats cool sory i could not help more.
annette's honda
Mar 31, 2013 09:42 AM
Method
Sep 17, 2010 04:43 PM
gunz4me
Apr 3, 2009 05:46 AM
noops
Oct 19, 2007 02:08 PM
nomak
Jul 7, 2005 08:57 AM
