Can I get the plexiglass off that protects the gauges ?
Old Jul 14, 2006 | 09:35 AM
vibeman's Avatar
Default Can I get the plexiglass off that protects the gauges ?
I have a 2002 Civic and I would like to take off the plexiglas that protects the speedometer and clean the back side of it. Somehow, some liquid dripped down
behind the glass and I can't clean it unless I take it off.
I see there are two screws above the plexiglass. Will this do it ?
I don't want to screw it up. So I thought I better ask first.
Thank you.
Old Jul 14, 2006 | 01:30 PM
jhsplaya08's Avatar
Default RE: Can I get the plexiglass off that protects the gauges ?
yes thats what does it. then there are some clips at the bottom that should just pop off.
Old Jul 17, 2006 | 08:25 AM
OpTiCaL's Avatar
aight so your best bet is to take out the whole cluster, its one big modular unit. k, here is a quick DIY from what i remember on PitchBlack's 02 Sedan...
1. Remove both screws in the top of the black plastic trim surrounding the gauges.
2. Now, pop out that piece. It will be kind of hard because there are two clips in the bottom, just pull kinda hard and it will pop out.
3. Now there should be 3 screws holding the gauge cluster in. I think its 2 on the side and 1 on the top.
4. Disconnect both wire clusters that plugin to the top of the cluster and pull it out of the dash.
5. Here is kind of the bitch part. Grab a standard screwdriver and pushdown all the clear tabs that suround the gauge cluster. I did the whole top first which made it real simple to get the bottom to slide right off.
6. Aight, it should all be apart now and all you gotta do now is not get it all dusty before you put it back together. Ummm, well i guess in this step you clean it.
7. Put the damn thing back together just how you took it apart!
TaaDa!!! *takes a bow*
I'll be here all day folks, lol.
Old Jul 18, 2006 | 08:52 AM
OpTiCaL's Avatar
So, did this help any and how close was i?
Old Jul 18, 2006 | 09:04 AM
khanselman's Avatar
^^ You hit it on the head.. I did this when I swapped my gauge cluster from a DX (tach-less pos) to an EX cluster..
Old Jul 18, 2006 | 12:03 PM
OpTiCaL's Avatar
Awsome, i think that would qualify as a DIY right there.
Sizzlinninja
Sep 30, 2013 12:05 PM
andrew porter
Feb 15, 2013 11:37 AM
shellebelle
Sep 6, 2007 08:12 AM
vtec02
Apr 12, 2007 12:32 AM
alarum
Oct 29, 2005 05:08 PM
