Sub Woofer Box Material
Old Nov 5, 2006 | 11:16 PM
CivicCrazy88's Avatar
Default Sub Woofer Box Material
What is a good wood to use to make a custom box for my car?...and maybe any ideas of material to cover the wood too?
Old Nov 5, 2006 | 11:55 PM
Pete's Avatar
Default RE: Sub Woofer Box Material
3/4 inch MDF. Medium Density Fiberboard. Cover it with speaker carpet?
Old Nov 6, 2006 | 11:13 AM
Is that what it is called just Speaker Carpet?...haha
Old Nov 6, 2006 | 11:34 AM
TheMoogly's Avatar
It is called gray felt... use some all purpose spray on adhesive glue to stick it on and you're good to go... I used Remmy's DIY to build my box and I love it! If you want pictures I'll send some on how I built it.
Old Nov 6, 2006 | 04:27 PM
natecivic92's Avatar
You can buy a plywood sheet size piece if fiberboard at lowes for under 20 bucks.
Old Nov 6, 2006 | 04:44 PM
Yea pics would be perfect if you wouldnt mind. I want to do this right so it looks good and pro qualitly without paying the money but it cant be that hard to build the box right?..
Old Nov 6, 2006 | 05:40 PM
TheMoogly's Avatar
Just know that I had a specific look I was going for in my trunk... FUNCTIONALITY! I can put stuff all around it and under it so i am waay happy with it.
I have a ton of more pix but this is a little bit of what I did with my friend.
Old Nov 7, 2006 | 11:31 AM
ok like this
most lumber.... home depo.... lowes.... andi think menards.....
carry it. just be sure its 3/4MDF
that way its heavy duty and the bass wont shake it to hell!!!!
but if your doing a tiny system under 500watts then 1/2inch MDF would probably be strong enough just might have to brace it alittle in the middle.
Old Nov 7, 2006 | 12:54 PM
matts's Avatar
get some good ol' OSB lol. j/k. i dont think 1/2 MDF is really worth the effort unless you just happen to have a sheet laying around. by the time you worry about trying to brace it and make sure it doesn't flex i'd rather just spend a few extra bucks and buy the 3/4.
Old Nov 7, 2006 | 01:45 PM
TheMoogly's Avatar
ORIGINAL: matts
He's right... and the board of3/4 from homedepot was like 40 bucks and the whole install costed about 70 bucks... but that is for a fully custom box that you will absolutely love!
And if you really want to go crazy, addiction2bass has the absolute perfect setup, although trunk space is less. As for loud, no doubt that addict's setup is the best, the sub facing up like mine is loud enough for me but gives me a little more room to work with...
