Clock
Old Feb 28, 2005 | 02:06 AM
1992civicsi's Avatar
Default Clock
G'day i've got a 92 Civic Si.
There is an electrical problem of some description.
When the ignition is turned off the time is reset everytime. When the ignition is on, the clock isn't, unless i press the button to the right of the "reset" button. When i press this button it turns on and is visible untill i let go of the button.
Any ideas?
thanks
Rohan
Old Mar 24, 2005 | 12:46 AM
Pete's Avatar
Default RE: Clock
hmm. If it were me id check the fuses. It may be runnin off a back up fuse or something. IF that fails try takin the negitive terminal off ur car and leave it for 10 or 15 mins to let the ECU reset. Those 2 ideas combined should do it. If problem persists just re post.
Old Mar 29, 2005 | 01:14 AM
Default RE: Clock
Yeh I've had a go of both of those ideas. No luck. I met a guy who has an 89 accord today who has had a similar problem. He said there is a solinoid behind the clock which probably needs resoldering. I'll give it ago when i've got a chance and tell you how i go. Thanks
Old Mar 29, 2005 | 01:20 AM
Pete's Avatar
Default RE: Clock
tru well if that doesnt work im sure u can pick up a new clock on ebay for a few bucks.......or just hit up the local junk yard and see if theyve got em. Its a pretty small item so it should be free dollars and ninty nine cents.
dalejrrocks8
Oct 17, 2004 05:14 PM
RonTL
Oct 12, 2004 10:10 PM
drrocket0302
Jul 20, 2004 11:30 PM
taffy
May 31, 2004 10:31 AM
froggy780
May 27, 2004 07:27 PM
