used d16z6
Old Dec 18, 2006 | 09:02 PM
seaton05261979's Avatar
Default used d16z6
I just bought a used d16z6 and I would like to know what i can do to ensure that the motor is in good working order? Could anyone gave me like a quick check-list of things to do or look at to make sure the motor is in decent shape? Any help would be much appreciated.
Old Dec 18, 2006 | 09:49 PM
cbaber's Avatar
Default RE: used d16z6
Well you should have made sure it ran before you bought it. If you didnt check to see if it was good before you bought it then I have no idea what you were thinking.
Old Dec 18, 2006 | 09:58 PM
I realize that now. Thats why i'm asking these questions, so if you don't have anything helpful to say then why are you writing me trying to make me feel dumber than I already must be. It was going to be a re-build from the beginning anyways, but if anyone else has anything intelligent to say, then I would appreciate it.
Old Dec 20, 2006 | 02:47 PM
Opened it up and everything looks good. Close post.
Old Dec 21, 2006 | 07:19 AM
I would run Compression and Leakdown tests on it. I for one don't take chances just because it "looks good"
Old Dec 21, 2006 | 09:25 AM
riceburner700's Avatar
pull plugs and wires
hook up compression tester in #1 spark plug hole
hold motor with a buddy
hold throttle body wide open
hook a battery up to the starter starting with positive first. when you hook up the negative the motor is gonna crank.
crank for 5-10 seconds
look at gauge and write down number
repeat for other three cylinders
the difference shouldnt be any more than 10% of the maximum cylinder
hope this helps
biocpu
Oct 6, 2008 12:16 PM
02CivicEX
Feb 7, 2005 04:01 PM
AggressiveAdam
Dec 10, 2004 03:20 PM
D16z6
Sep 19, 2004 02:56 PM
slideman99
Aug 3, 2004 06:10 PM
