used d16z6
I just bought a used d16z6 and I would like to know what i can do to ensure that the motor is in good working order? Could anyone gave me like a quick check-list of things to do or look at to make sure the motor is in decent shape? Any help would be much appreciated.
I realize that now. Thats why i'm asking these questions, so if you don't have anything helpful to say then why are you writing me trying to make me feel dumber than I already must be. It was going to be a re-build from the beginning anyways, but if anyone else has anything intelligent to say, then I would appreciate it.
pull plugs and wires
hook up compression tester in #1 spark plug hole
hold motor with a buddy
hold throttle body wide open
hook a battery up to the starter starting with positive first. when you hook up the negative the motor is gonna crank.
crank for 5-10 seconds
look at gauge and write down number
repeat for other three cylinders
the difference shouldnt be any more than 10% of the maximum cylinder
hope this helps
hope this helps
slideman99
Aug 3, 2004 06:10 PM
