vtec switch
Old Dec 28, 2006 | 10:20 PM
98civicex5spd's Avatar
Default vtec switch
i have already seen mixed reviews of changing the vtec engagement point. i have been recently shown that if you send 12v power to the vtec solinoid(i cant spell for ****) you can actually make it engage as low as idle. the only downfall is the cel that comes up, and the fact that for some unknown reason the rev limiter initiates at 5500 rpm instead of 7500. how accurate are the stock tach.s by the way. all this is on a 98 d16y8 stock. only aftermarket is fart can and cheap intake
Old Dec 28, 2006 | 11:07 PM
cbaber's Avatar
Default RE: vtec switch
I really dont understand why you would want to do that. VTEC is not like nitrous.
Optimal low RPM valve timing, lift and duration settings would result in insufficient fuel and air at high RPM, thus greatly limiting engine power output. Conversely, optimal high RPM valve timing, lift and duration settings would result in very rough low RPM operation and difficult idling.
Now after reading that I would think that having VTEC on at a low rpm would make your engine run worse. It engages at a high rpm for a reason. Please someone correct me if im wrong. WikiPedia cant teach you everything!
Old Dec 28, 2006 | 11:11 PM
Misha's Avatar
You are absolutely correct, cbaber. Vtec in two words is like having two cams - one for low rpm, and one for high. Using high rpm cam for low rpm is not going to do you any good.
Old Dec 29, 2006 | 01:17 PM
Skrapdoggydog's Avatar
i wouldn't mess with ur vtec engagement point. the engineers at Honda have it set at a certain rpm for a reason. optimum performance and reliability.
Old Dec 29, 2006 | 03:11 PM
devney's Avatar
Yeah I never understood why people change the engagment point. It's set where it should be.
Old Dec 29, 2006 | 04:15 PM
Mr Mobsta Man's Avatar
1. I don't see why ppl do it either.
2. If your going to do it anyway then get a vtec controller, it's got to be safer than trying that 12v trick.
Old Dec 29, 2006 | 11:08 PM
zerocool's Avatar
Sometimes you just blow the engine to say "well, I guess I shouldnt have dont that"... very effective teaching but hard on the wallet
Old Jan 5, 2007 | 09:52 AM
ORIGINAL: Skrapdoggydog
i'll give ya reliabilty but i dont think they engineered all the Civic for high perfromance right outta the factory
but i wouldn't mess with it either man, seems like the more power you got the, the less reliable it is and vice-versa
Old Jan 5, 2007 | 12:02 PM
Misha's Avatar
Again, one can try to play with it around original engagement point a few hundreds rpms up or down and see if he likes his middle band power better this way, but moving the point all the way down to the idle does not make any sense at all and effectively eliminates ALL the advantages of vtec.... You might as well get non-vtec head and install racing cam - the same result
danomatic93
Routine Maintenance DIYs
Jan 15, 2012 07:16 AM
Booger
EK Swaps
Aug 9, 2011 10:11 PM
ic892003
Mar 4, 2007 08:37 PM
b16Ek4
Jun 20, 2005 10:59 PM
b16Ek4
May 25, 2005 08:48 AM
