oil fill plug?
Old Mar 10, 2005 | 07:35 PM
ohbiskits's Avatar
Default oil fill plug?
can anyone take a pic or explain to me which plug is the oil fill on a 4th gen cable tranny...the one i think it is cant be it cuz its just abotu imposible to get to
Old Mar 10, 2005 | 07:54 PM
finalimpact's Avatar
Default RE: oil fill plug?
heres what i do and it works everytime for me. remove the reverse switch located at the top of the transmission. find a funnel that fits into the hole, then fill. the fill plug on our trannys are by far the worst engineered IMO.
Old Mar 10, 2005 | 08:03 PM
ohbiskits's Avatar
where is the reverse switch?
Old Mar 10, 2005 | 08:09 PM
ohbiskits's Avatar
is it the electrical connector that has 2 wires that run somwhere by the dizzy?....u take it off with like a 17mm wrench?
Old Mar 10, 2005 | 09:27 PM
more or less below the dizzy. yes it has 2 wires and it is removed with a 19mm wrench.
Old Mar 10, 2005 | 09:59 PM
ohbiskits's Avatar
yea i got it...thanks alot...how much would u recomend putting in...i put like 1.5 -2 quarts....shoul;d i add more or?
Old Mar 10, 2005 | 10:08 PM
i have always used 2qts
Old Mar 11, 2005 | 04:30 PM
ilinihonda's Avatar
There is a fill hole on the bottom part of the tranny I think 17mm if I remember right. The book says to fill until it will drain back out same hole. The problem with that is it's on the side so a regular funnel won't work. It says to use a syringe, or I imagine a flexible small type funnel would work dropped down from the top of the engine. I used a rubber hose duct taped to the funnel. It isn't too bad to get to from under the car. [:@]
Old Mar 11, 2005 | 09:34 PM
thats what i use too. or this funnel i got that has a soft hose on the end, that works great too.
therobesons
Oct 6, 2008 11:47 AM
oilltd
Jun 10, 2008 04:06 PM
Gen5unknown
Jan 12, 2008 06:04 PM
bakon91
Nov 27, 2005 04:30 AM
