The check engine light illuminated again!?
Old Feb 16, 2007 | 09:50 AM
yairsaenz83's Avatar
Default The check engine light illuminated again!?
Yesterday I replaced the o2 sensor on my '98Civic Dx. I did this after a test from Autozone said the sensor after the cat converter was faulty. This morning on my way to work the darn check engine light illuminated again. What could the problem be?[:@]
Old Feb 16, 2007 | 09:54 AM
Default RE: The check engine light illuminated again!?
wel maybe you should trust the guy, maybe your cat is bad. And if you need to replace it, maybe you could get a nice name brand high-flow cat and get an extra hp or two
Old Feb 16, 2007 | 03:12 PM
kimsuprapa's Avatar
Magnaflow makes nice cats. Don't go for the "racing" cat tho b/c that's straight thru + I'm pretty sure u won't pass inspection.
Old Feb 19, 2007 | 02:26 PM
ORIGINAL: FlipHKD720
The Autozone guy said it was the sensor that was bad, not the cat
Old Feb 19, 2007 | 02:30 PM
My04Civic's Avatar
Administrator
have them look at the sensor under the hood
Old Feb 19, 2007 | 06:48 PM
StifflersMom's Avatar
Cat Fuсker
did you clean the mating point of the sensor with the pipe with a wirebrush? Corrosion there could compromise the ground connection.
komobu
Jul 23, 2013 01:15 PM
wil
Jan 18, 2013 04:27 AM
robert.walter
Jan 4, 2012 05:41 AM
towelie
Aug 30, 2010 05:08 PM
