rods and pistons
Old Feb 21, 2007 | 06:07 PM
stylincompact's Avatar
Default rods and pistons
hey guys someone told me i needed to have my rods and pistons press fitted together is that true or can you just put them together?
Old Feb 22, 2007 | 08:54 AM
HybridGarage's Avatar
Default RE: rods and pistons
If they are stock pistons and rods, Yes thay need to be pressed
If they are aftermarket thay have a flouting pin and you can do it your self.
Old Feb 22, 2007 | 09:00 AM
vitara pistons and eagle rods
Old Feb 22, 2007 | 01:37 PM
those seem to be aftermarket, so you should just be able to use the pin
Old Feb 22, 2007 | 10:34 PM
riceburner700's Avatar
try and slide the wrist pin through the piston and into the rod, if it doesnt slid in then take them to a matchin shop and have them pressed in.
Old Feb 23, 2007 | 08:57 AM
cpl rampage's Avatar
thoes are fully floating pins, so u can put them together ur self, all u need is a clip ring compressor
Old Feb 23, 2007 | 09:15 AM
there should be a little indent that you put half the clip in on the oppisite side were its suppost to be and just push the clip in were the indent is with like a punch by hand or like a flat tip screw driver.
Old Feb 23, 2007 | 12:44 PM
ORIGINAL: riceburner700
thats true, but then you could also risk gouging the metal, and then making an edge that will wear on the cylinder walls, i would sugest spending 10 bux and getting a clip ring remover/installer
tombakers
Nov 15, 2007 05:05 PM
95coupe
Jun 15, 2007 11:15 AM
t34me
Sep 12, 2006 09:55 PM
POSCivic
Feb 20, 2006 03:13 AM
WillVTEC
Jun 11, 2005 08:00 PM
