EG Swaps 1992-1995 Civics
which mini-me swap?
Old Feb 22, 2007 | 09:18 AM
ic892003's Avatar
Default which mini-me swap?
i have a d15b7 sohc non vtec engine, instead of doing a full swap i was thinking what is a good head swap i should do??? i was thinking maybe ls or b16 maybe???, what else is needed in a head swap i know its easy since u dont have to change the tranny or axles...... but what else ecu??
Old Feb 22, 2007 | 09:34 AM
Kedawei's Avatar
Default RE: which mini-me swap?
Z6 everything if you stick with the D.
Old Feb 22, 2007 | 10:45 AM
ic892003's Avatar
i plan to pick the head up form the junkyard, wut shouldi mkae sure they include with the head?
Old Feb 22, 2007 | 11:17 AM
ic892003's Avatar
also do u recommend i change any internals when doing this mini me
Old Feb 22, 2007 | 08:00 PM
Kedawei's Avatar
Get everything from the top of the block up, and the ECU. Do a search for mini me for a specific list of parts. Internals would be a good idea for anything over 200hp or 8000rpm. Your internals choices are limited to Crower, or custom rods from another manufacturer, and plenty of OEM or aftermarket piston options.
Old Feb 22, 2007 | 10:57 PM
ProjectGSR's Avatar
Im doing the same mini me (for now) and this is all the info you need!!
https://www.hondacivicforum.com/m_45390/tm.htm
Old Feb 22, 2007 | 10:59 PM
ProjectGSR's Avatar
oh and you know you can ONLY use D series heads on that B7 right??
Old Feb 23, 2007 | 11:31 AM
Kedawei's Avatar
Use Z6.
Old Feb 23, 2007 | 12:14 PM
ic892003's Avatar
yea i know that, at least now i do lol, wow thanks for the thread gsr, maye i should tryo to do this nmyself, do i have 2 get the ecu for the z6 or can i use the ecu thats currently in my car?
Old Mar 20, 2007 | 12:28 PM
my94civic's Avatar
you will have to use the exu from the z6 as this ecu has the data on it to control the VTEC
unless the ecu that is already in your car is a VTEC ecu. . . from what im lead to believe anyways ahaha
chbulldogs11@msn.com
May 27, 2011 09:05 PM
khanselman
Aug 25, 2006 12:40 PM
TicKeR_96_HaTcH
May 27, 2006 08:55 PM
nemesis08
Jun 8, 2005 08:05 PM
GSXF
Feb 23, 2005 09:45 PM
