wet and dry nitrous
Old Mar 19, 2005 | 05:47 PM
Nail I3unny's Avatar
Default wet and dry nitrous
whats the difference between 'wet' and 'dry' nitrous oxide systems?
Old Mar 19, 2005 | 06:46 PM
Patrick's Avatar
Administrator
Default RE: wet and dry nitrous
wet shot meant that your nitrous line is spliced in with your fuel line, thus when the nitrous is injected, it has a small amount of gasoline mixed with it...it helps to prevent from extreme leaning conditions which are naturally caused by using a nos mixture....dry shot is simply the nitrous gas, injected alone....
dry shot kits are much easier to install, due to the lack of having to splice into your fuel line...also with a wet shot system, in the case of a V6....you have to fuel rails to deal with...but the wet shot kit is MUCH safer...if there is such a thing as a safe nitrous kit...i have driven/raced a bottled car..and it is quite a bit of fun...until it blows up...[&o]
Old Mar 19, 2005 | 07:02 PM
wow thx uve really boosted my confidence in the stuff :P
Old Mar 19, 2005 | 07:04 PM
Patrick's Avatar
Administrator
i mean..for instance...we bolted a wet kit 55 shot onto a car, and it was a bit of a pain to install it...but it went from running 16.50s to 15.40s...on an engine with 160k on it...and it ran for a whole race season...spraying on the street and track...but 55 isnt a very heavy shot...
Old Mar 19, 2005 | 08:59 PM
on the stock motor in my car, we ran a 50 shot dry, and went from a 17.2 to a 15.4. but after awhile, N2O gets old, and youre gonna want a turbo or SC.
Old Mar 20, 2005 | 08:44 AM
Patrick's Avatar
Administrator
wow..thats a GREAT jump for a 50 dry shot...the bottle was the only change you made??
Old Mar 20, 2005 | 11:50 AM
yeah, it had a short ram too, but it had it before and after, so the only change was the bottle between runs.
Old Mar 21, 2005 | 09:44 AM
turbob18c1's Avatar
the wet mixes the nitrous with fuel and is allot safer to use b/c of the extra fuel. the dry is just nitrous. when used w/o any richining and a high shot (100) then ur asking for trouble
Old Mar 21, 2005 | 02:55 PM
Kappa22's Avatar
Direct port is always preferrable to either of the other two, but is also quite a bit more expensive...
bullridingndn
Jan 19, 2009 09:39 AM
Mr Mobsta Man
Jun 18, 2008 03:59 PM
sjmcgarrah
Jul 24, 2007 06:13 PM
GotRice?99ex
29
Apr 7, 2006 01:36 AM
Pete
15
Apr 6, 2005 08:45 PM
