EG Swaps 1992-1995 Civics
Shift linkage/Motor mounts
Old Mar 10, 2007 | 03:35 PM
natecivic92's Avatar
Default Shift linkage/Motor mounts
I have a eg 92 manual d15b7 now.I am putting the b18b1 into it I have 2 questions I have b18b1 mounts that are from an automatic ls.Do I need to get manual b18b1 mounts for the (manual b18b1) to bolt up in my eg. I also hear I need a shift linkage which civic or were can I get 1 at so the b18b1 will work in my 92 civic.Thanks
Old Mar 10, 2007 | 03:39 PM
Fiirkan's Avatar
Default RE: Shift linkage/Motor mounts
I am pretty sure you need the linkage from a DA integra for that swap. as for the motor mounts i dunno i would assume they would work, but then again i also assumed that i wouldn't have to replace a motor mount when swapping in a D15B but i will have to.
Old Mar 10, 2007 | 03:52 PM
What is a Da integra Is that the car the tranny came out of?
Old Mar 10, 2007 | 07:30 PM
Fiirkan's Avatar
no the B1 came out of the 94-01 integra, but if i recall properly it calls for linkage from a DA(90-93), but i think you can use the linkage from a 94-01 as well. my brain is on overload right now from work so i can't remember 100%
Old Mar 10, 2007 | 09:18 PM
I found a 96 acura integra ls manual tranny at one of them you pull it yourself junkyards.I already have the 2000 b18b1 engine and all the stuff but its automatic tranny,So I am going to get the flywheel,clutch,tranny,axles,starter,out of the 96 integra manual tranny.I was just wondering what else I need to get off 96 ls to do my swap any while I am there if I need the mounts and shift linkage might as well pick them up.
Old Mar 16, 2007 | 02:15 PM
milanoej1's Avatar
u might as well get the mounts off the dc...and also dont forget the slave cylinder(if it isnt already on the tranny)..and also if i were u id replace the mounts to near new mounts
Old Mar 17, 2007 | 12:02 AM
riceburner700's Avatar
you are gonna need to get the manuel tranny b18 mount the other 2 should bolt right in. also use the integra shift linkage
Old Mar 17, 2007 | 02:34 AM
I will i'll grab that back tranny mount and the shift linkage from the car also Thanks.
lsvteccivic
Feb 10, 2006 09:26 PM
91crx_87
Jan 24, 2006 08:58 PM
twon
Sep 29, 2005 11:44 PM
twon
Sep 26, 2005 08:55 AM
S240161
Jul 28, 2005 03:36 PM
