HELP...problem with trans
Old Mar 23, 2005 | 11:01 AM
nino's Avatar
Default HELP...problem with trans
i have a 98 civic lx with a 5speed ,and there is noise coming out of the gearbox when i push th e clutch in it makes almost like a winding ,grinding,ratteling type sound even in neutral it makes the noise the only time it doesnt make the noise is when i push the clutch in and when i first start up the car and the engine is cold i already changed the fluid in tranny i thaught maybe that would help and its still the same
Old Mar 23, 2005 | 11:00 PM
Default RE: HELP...problem with trans
sounds like maybe a throwout bearing. does it only go away if you press the pedal all the way down, or does it go away with just a little pressure?
Old Mar 24, 2005 | 09:24 PM
nino's Avatar
thanks for responding, the tranny makes the noise when i press the clutch all the way down in neutral and in gear but when its in gear and i let off the clutch it is alot louder.
Old Mar 27, 2005 | 10:45 PM
nino's Avatar
bump still need help
Old Mar 27, 2005 | 11:51 PM
ohbiskits's Avatar
id say its the throw out bearing...but u say its louder in gear with the clutch out?
Old Mar 28, 2005 | 01:44 PM
jwsimons's Avatar
im having the same problem, exactly..more load louder it gets? kinda sounds like a kid with cards in his spokes? but deeper? i've tried changing fluid also, and i keep checking to b certain its full ( cuz its sounds dry), i was wondering if somehow the starter might be not pulling back far enough, or something is a different pitch.. is this the car you just did the 4 to 5 speed? thats what i have done also. i used a crx '91 in my '88 hatch. if we both have same symptoms from the same upgrade we have overlooked something obvious.. did you install new clutch at same time? i did. new throw out bearing also. if i find anything i'll let you know.. please do same.. i want that chatter gone
Old Mar 28, 2005 | 01:46 PM
jwsimons's Avatar
duh!!!! for some reason i thought this thread was started by ohbiskits... so ignor the reference q's. in prior post
Johnny G
Aug 15, 2012 09:12 PM
pippo
Sep 12, 2008 04:06 PM
yetti8
Oct 1, 2007 10:26 AM
bonzitre
Jan 21, 2007 08:51 PM
Lordnismo
Sep 26, 2006 03:07 AM
