crx si dash wirng in a 90 dx
Old Apr 5, 2007 | 07:45 PM
civtec00's Avatar
Default crx si dash wirng in a 90 dx
i have a 1990 civic hatchback dx with no tachometer. i got a dashboard, gauge cluster with the tachometer, and the dashboard wiring from a 90-91 crx si. i left the harness from the si on the back of the dashboard,and i started to plug everything in, but one of the big plugs on the bottom near the fuse panel does not plug in. its shorter. would i have to use the rest of the harness from the crx, or can i change some of the plugs around? thanks
Old Apr 5, 2007 | 08:37 PM
ef4life's Avatar
Default RE: crx si dash wirng in a 90 dx
it should be a plug in swap. are you sure its not from and 88-89? anywho you can match up most the wires i belive anduse the old plug.
Old Apr 6, 2007 | 06:08 PM
civtec00's Avatar
ill have to recheck the year with one of my friends. thanks for the info.
addiction2bass
Apr 27, 2012 05:17 PM
addiction2bass
Mar 26, 2011 03:42 PM
macchu43
Apr 18, 2009 10:20 AM
yamahaSHO
Jun 14, 2006 05:36 PM
dmsteele92831
Apr 11, 2005 12:46 AM
