clutch.
Old Jun 10, 2007 | 03:58 PM
Method's Avatar
Default clutch.
well clutch kinda crapped out on me today. the pedal wasn't working, and couldn't get into gears. i press the clutch pedal and it would stay down, and not release. car went on a flatbed. sucks seeing your car on a flatbed. you think that it could be just the pedal part?
Old Jun 10, 2007 | 04:32 PM
absoulute's Avatar
Default RE: clutch.
usually the clutch will slip before it goes . so the question would be was it slipping before. was there any pressure in the clutch pedal or when u pushed it did it just go to the floor and stay there.
Old Jun 10, 2007 | 04:52 PM
Default RE: clutch.
dito... check the cables... HOEPFULLY the cable just snaped... but if the cable works fine NOT GOOD... could be busted fork
Old Jun 10, 2007 | 04:55 PM
Default RE: clutch.
It's a hydraulic system like the brakes. Probably something let go and all the fluid leaked out. The clutch itself is OK, just it isn't linked to the pedal any more.
When your clutch is worn out, you can shift into gear, but the car won't move.
Old Jun 10, 2007 | 04:58 PM
absoulute's Avatar
Default RE: clutch.
look under the dash and see if there is fluid all over if so its the master cylinder. if not it could be the slave cylinder. either way easy to fix and not to expensive...
Old Jun 10, 2007 | 05:28 PM
Method's Avatar
Default RE: clutch.
the pedal will go all the way, and stay there. clutch wasn't slipping. i didn't look for any fluids, hopefully it's just a cable or fluid. hoping it's cheap. i got no money. i just bought a house. so i have non.
Old Jun 11, 2007 | 01:32 PM
Method's Avatar
Default RE: clutch.
the slave cyldiner was the trouble. got it all fixed.
Old Jun 11, 2007 | 03:13 PM
absoulute's Avatar
Default RE: clutch.
how much did they rack you for that. shouldn't have been to bad its right there in the front real easy to get to (atleast on the b series it is)
Old Jun 11, 2007 | 04:15 PM
Method's Avatar
Default RE: clutch.
wasn't that bad, the ball joint and upper control arm had to get fixed at the same time, but the slave cylinder installed, bled the lines and all that ran about 150.
Old Jun 11, 2007 | 05:49 PM
absoulute's Avatar
Default RE: clutch.
ahh that ain't bad at all. the bleeding part was a pain in the ***.
VXHatchHero
Jun 13, 2010 09:42 AM
NIKE H34D
Jan 5, 2009 01:04 PM
addiction2bass
Apr 13, 2008 05:19 PM
jtvision
Jan 11, 2007 07:58 AM
HARI.
Oct 8, 2006 09:46 PM
