Clutch Tension Issues, Clutch? Master Cylinder? Slave?
Old Jun 13, 2010 | 08:45 AM
VXHatchHero's Avatar
Default Clutch Tension Issues, Clutch? Master Cylinder? Slave?
Thanks for taking a look,
The other day i was driving my hatch back home from a friends, my clutch was losing tension and i would have to pump it to even be able to shift, is just started to happen last night. It even stalled at one point randomly when i was at a stop sign attempting to shift into First. So basically
I have no pressure on my clutch so i cannot engage it to shift, i can start my car but cannot shift into a gear or drive it. I check fluid levels and theyre love, but not completely gone. I was wondering if this sounds like a worn clutch issue or something else, please help my cars stuck in some parking lot till my insurance stops being difficult and tows it T_T
[[Stage one clutch, short throw.]]
and its lowered and was nightt time and raining when it happened, so i have yet to jack it up and look underneath, Thanks again!
Old Jun 13, 2010 | 08:57 AM
Check for fluid leaks above the clutch pedal or on the firewall side of the master cylinder. If a leak is found replace the master cylinder and bleed the system.
Likewise replace the slave cylinder at the front of the clutch housing if it leaks.
Old Jun 13, 2010 | 09:18 AM
i did check earlier and i dont believe i was losing fluid, but ill double check again today. I was thinking ill just start with a simple bleed to see if thatll help any, it gradually just stopped being able to engage, so im hoping its not too difficult a fix.
Old Jun 13, 2010 | 09:37 AM
If there's air in the system, it likely entered due to a leak. If there's no leak, then the master or slave cylinder is bad. A less likely possibility is a broken clutch fork.
Old Jun 13, 2010 | 09:42 AM
true, thanks alot now i can at least take a look at things and start gettig my civic back into shape haha
bcivic
Mar 1, 2008 10:01 AM
saturn78
Apr 19, 2007 01:36 AM
sway2003
Dec 27, 2006 07:33 PM
01CivicEX
Apr 20, 2006 01:38 PM
JDMcivic
Sep 19, 2005 08:57 AM
