slave cylinder question
Old Sep 9, 2005 | 11:14 PM
JDMcivic's Avatar
Default slave cylinder question
got a 96 DX civic with a JDM B16A swap...lately ive had a problem gettin in gears mainly third itl grind going intoand no others unless i try to drop gears then itl grind that gear or if i try to shift quick. Its hard to get into any gear though. As of tonight however it got really bad and now ill push my clutch in about half way before itl start engaging at all and when im driving if i put the clutch in it doesnt engage immedietely if at all..I think this is the slave cylinder problem but im not sure so please any help soon as possible
Old Sep 9, 2005 | 11:24 PM
sacicons's Avatar
Default RE: slave cylinder question
it sounds more like your clutch is toast.
Old Sep 18, 2005 | 03:36 PM
315 Customs's Avatar
sounds syncronizers (sp) to me which isnt good if it is
Old Sep 18, 2005 | 03:44 PM
chaseman1978's Avatar
ORIGINAL: 90Civtegra
if it was the syncronizers, it should do it on all shifts, not just going into 3rd...
Old Sep 19, 2005 | 08:57 AM
no not true because you can just have a certain syncro go out. I had lost 3rd gear syncro on my Z24 before and had to replace the whole tranny (it was just cheaper that way) and it would grind terriblely going into 3rd gear but only 3rd gear
VXHatchHero
Jun 13, 2010 09:42 AM
bcivic
Mar 1, 2008 10:01 AM
saturn78
Apr 19, 2007 01:36 AM
sway2003
Dec 27, 2006 07:33 PM
01CivicEX
Apr 20, 2006 01:38 PM
