94 clutch problem??
Old Jun 14, 2010 | 06:39 PM
rwayne68's Avatar
Default 94 clutch problem??
i have a 94 civic lx 1.5.... clutch bearing was squealing for about 2 weeks then clutch pedal at start up went to the floor and stayed there...is this a master cylinder problem or slave clutch problem , or could the clutch itself went out... i need to know how big a problem may need fixed...any help thanks..
Old Jun 14, 2010 | 07:43 PM
Check whether clutch release fork is broken. It also could be that pressure plate is toast.
Old Jun 15, 2010 | 08:28 AM
StifflersMom's Avatar
Cat Fuсker
Could also be a leak in either the master or the slave. See if you have any fluid on the slave, on the firewall or around the clutch pedal.
VXHatchHero
Jun 13, 2010 09:42 AM
NIKE H34D
Jan 5, 2009 01:04 PM
addiction2bass
Apr 13, 2008 05:19 PM
jtvision
Jan 11, 2007 07:58 AM
HARI.
Oct 8, 2006 09:46 PM
