Short Shift Adaptor or Short Throw Shifter
Old Apr 22, 2005 | 08:10 PM
05CivicLX's Avatar
Default Short Shift Adaptor or Short Throw Shifter
Want to shorten the throw, but I came across two different types. A short shift adaptor and the short shift lever. Is one of these better than the other? Can you use both? Is there any advantage to using both?
[IMG]local://upfiles/2869/57EA55A6777041ED8D65B73D40C82A50.jpg[/IMG]
Old May 24, 2005 | 04:33 PM
DT Precision Tuning's Avatar
Default RE: Short Shift Adaptor or Short Throw Shifter
I like the actual short shift lever rather than the adapter becaust in most cases the leve will give you a shorter throw than the adapter.
Old May 30, 2005 | 01:41 AM
clutchjunkie's Avatar
maybe i'm wrong, but i thought the S.T. adapter was something you needed in order to attach the s.t. shifter.
Old Jun 4, 2005 | 12:46 PM
Dickie's Avatar
Member
you dont need the adapter for the shifter.. pick either. its best to get a new shifter because ure stock one isnt going to handle too much abuse and will break fairly quik if u are racing. make sure its steel and none of that alluminum ****.
warner_ro
Aug 8, 2007 05:46 PM
redlines4us
Oct 10, 2006 05:02 PM
eLantern
Aug 29, 2006 01:08 PM
mxs
Drivetrain DIYs
Jun 12, 2006 09:51 PM
red_sleeper
Feb 2, 2005 05:20 PM
