EG Swaps 1992-1995 Civics
engines
Old Apr 28, 2005 | 12:43 PM
martinr_440's Avatar
Default engines
i was just wonderin Will a DOHC ZC j-spec engine fit in a civic between 1992 and 1995.
Old Apr 28, 2005 | 06:59 PM
Kappa22's Avatar
Default RE: engines
There are two different black top DOHC ZC's: The most common is the yellow plug version (straight drop-in for 4G's, 130 hp, 108 tq), and then there is the harder-to-find gray plug version (140 hp, 109 tq) that will drop right into a 5G. Good luck finding one though.
Old Apr 28, 2005 | 08:29 PM
AnakinKenobe's Avatar
Default RE: engines
So yes it will you just need to purchase the proper mounts, last i checked it was around 1k for the mount from where i am in MD, and i can think of alot of bolt ons i could purchase for my sohc d16 motor..
Old Apr 28, 2005 | 09:17 PM
Default RE: engines
im pickin up the engine this summer i was offered it for $1500cnd it has AEM cam gears, crane cams and a 2 peice header.
Old Apr 28, 2005 | 09:57 PM
Kappa22's Avatar
Default RE: engines
Sweet deal. But a mount kit should only run you around $300-400 USD...
Old Apr 28, 2005 | 10:37 PM
blackeyes's Avatar
Default RE: engines
i was gonna say go with a b16 but if its semi cuilt, sounds like a good deal.
Old Apr 29, 2005 | 01:55 PM
Default RE: engines
been doin some reaserch on the net. I havn't been able to find any ZC Dohc swaps into a 5g civic. Seems like too much of a struggle to try so when i get it i might just sell it and go for a b16
Old Apr 29, 2005 | 04:24 PM
Nail I3unny's Avatar
Default RE: engines
b16 is more expensive than a zc by far
Old May 3, 2005 | 05:34 AM
Kappa22's Avatar
Default RE: engines
Not actually much more than a gray-plug ZC. Those are helza rare.
Guitardude_15
EK Swaps
Aug 8, 2008 04:27 PM
elmarko152
May 31, 2005 05:30 PM
gxr03
Apr 2, 2005 06:39 PM
pedroquinonez
Mar 20, 2005 08:28 AM
sacicons
12
Aug 21, 2004 10:21 AM
